Genome said:
Larry Brasfield said:
[Previous quotes repaired for inadvertent line-wrap.]
Very kind of you, we certainly like to follow what's being said in a
Larry Brasfield thread.
Cute. While your insinuation is superficially plausible,
my note reflects only my intention to quote accurately.
Your post, when quoted normally, was a mess. I've
done the same repair again here. Why not just adjust
your line-length limit and get past this?
message news:
[email protected]... [Bloggs "contribution" cut for relevance and taste.]
Larry Brasfield wrote:
#2 big power xformers can saturate at turn on due to residual flux.
This causes them to draw a very large current spike. look up
trasnforer flux stauturation at turn on.. the only sure cure is to
soft start it first. Maybe you can use two realys, one through a
resistor, or maybe you can use a PTC soft start device in series.
That is a good point, and very relevant. However, I will quibble
with both the cause and the cure. When a line transformer is not
designed to handle about twice the peak magnetic flux that occurs
during steady state operation, and is switched on near a voltage
zero-crossing, it can saturate, often with an audible "whump". In
addition to the cure you mention, two others are available. One
is to switch on near a voltage peak. (This is counter-"intuitive",
so please consider carefully before contradicting this.) Another
is to specify a transformer with enough more iron that it will not
saturate upon turn-on regardless of the starting phase. ....
Well Larry, once again your delivery leaves a lot to be desired.
You agree there is a problem but you want to quibble about the cause
and the cure. Then, not only do you not properly explain the source of
the problem or why your cure works. You choose to issue a challenge to
anyone who questions your statements.
The reason for quibbling about the cause is because it has
clear implications regarding the possible cures.
So, I don't suppose you'd like to explain those 'clear implications'.
Is that not obvious by now? Do you honestly believe that
anybody who cared was unable to make that connection?
You didn't quite do it but you practically told Mark he was wrong.
I disagreed in a minor respect with his assignment of cause.
Are
you now saying that he may have had a point? Do you want to include it
in the explanation you are not going to give?
I thought Mark had a good point, and stated as much.
But you wanted to, and did, talk in terms of flux. Fair enough there
is a relationship but, again, you're choosing to avoid a full
explanation. You start to give a partial explanation but next..... you
say you won't.
Yep. The light appears to dawn. I am not going to be giving
tutorials on magnetics, basic RLC circuit theory, or anything
else without good reason and a favorable cost/benefit ratio.
Hang on, you were responding to Marks post. There's a not too subtle
difference here. You tell Mark he is wrong and then you refuse to
explain why because someone else asked a different question.
I had no reason to believe Mark even wants or needs such
an explanation. For all I know, once he thinks about the
issue for awhile, it is as obvious to him as to me. Maybe not.
If not, he is certainly free to ask why I quibble with his cause.
But...... you didn't..errr.... so you can't. Deny it that is.
I did deny it. You may not be happy with my proof,
but my denial is in plain English. Get a dictionary.
[Silly baiting banter cut.]
OK, on second reading I'll give you that. However you might like to
group your information rather than spread it about. It makes
interpretation and understanding easier.
That paragraph could have been clearer. With more
time invested, it might have been.
That's a bit pretentious isn't it?
No.
I'm sure there are people who would
like to know.
If you are so sure, why do you not follow thru on your
implied promise to educate them? My own estimate is
that few if any who read it would learn anything from it.
And playing your silly game is not rewarding enough to
justify the time expenditure.
Well that appears to be a half hearted attempt at something that
wasn't a correct answer. And it wasn't succinct. So you don't know.
So you say. Of the dozens of reasons I might have for
not expounding on something, you choose 'ignorance'
without the slightest evidence. That choice reflects your
state of mind, not mine.
By the way, how do you manage to write so much stuff with so little
content so quickly?
It's partially a function of the audience. An ARRL member
once explained to me, as a boy intrigued by his transmitter,
why receivers were much more challenging to design.
