funster said:
Thanks all... Wow... the talent out there is amazing. And to think
that my company was quoted from an engineering company to do the job
for $30,000. The circuit I named was just the most basic one possible
though. They would have added a recorder and a signal sent up to
supervision when the operator violated the %50 duty cycle requirement.
Keep the suggestions coming though and you may have earned a promotion
for me. LOL
Well,
That $30,000 looks pretty much to me. But on the other hand, there certainly
*has* some work to be done. Customized solutions tend to be expensive.
Let's recapitulate. Somewhere some operator has to activaty some equipment
and starts it. Some detector finds out and some clock starts to tick. After
five minutes the clock raises some alarm while continuing ticking. Some
operator deactivate the equipment. Some detector finds out and the clock
start to tick in the reverse while signaling somehow that the equipment
should have been to leave alone until the clock is back on its starting
point. It should be nice to also raise the alarm when someone activates the
equipment during that period.
Be aware that the principle is not very interesting from an engineering
point of view. As we have lots of sheep electronics these days, an
electronic solution seems the best. Half a century ago one would use some
relays, switches and a small motor for instance.
But some tasks has to be done for every solution. You have to find out how
to sense that the equipment is on. Decide what components you need, build
the detector and find a way to install it. No need to say it has to be safe
and reliable. Most of this part of the design depends on information you did
not provide. So do the costs.
On the output side you need some alarm. Both audible and visual components
are available in wide ranges and versions. You have to decide what satisfies
your needs and how and where it has to be installed. The same counts for the
signaling whether or not the equipment is ready for use.
Now you need some processing unit, the clock. Whatever you build, you will
need some power supply, some chassis or PCB and an enclosure for it.
My choice would be to buy some of the shelf enclosure. As I need only one of
a kind, I would use some prototyping PCB with a micro - an eight pins PIC or
AVR will do - two signaling LEDs and a driver for the audible alarm. The
latter can find a place in the enclosure as well along with some input jack
to connect the on/off sensor. I can do so while I have the skills and
equipment to program the micro. As for the power supply I would use an off
the shelf 5V wall wart.
Note that allthough $30,000 is still pretty much, you will for sure need
some thousends to get this all done by a professional.
petrus bitbyter
