I don't think the camera would handle the head associated with reflow, it might melt the plastic. So you could, but it's not ideal get some Sil strips 1mm pitch and solder them to the pads, put a nice bit of solder around the pins, it will be fragile so be careful. You could then make a PCB for this. I would personally see if I could solder some wires to the pad and use that instead. You could add a small amount of Tak-Pak to the wires to help secure them.
Adam
