Help locate; BLUE 7 Segment LED Display Anode
Hi crew, I've been working on a project (Vechical- Turbo Boost Gauge). I don't like the current RED 3x 7 Segment LED Display, Common Anode. And want to replace with same type but BLUE in colour.
Problem is I've been searching for a replacement, with many, many, many email to find one without any luck. So now I thought to try out you guy's to help me locate these. I've exhausted all known means to locate this item, without any luck (The measurements are L11mm X W6mm) 3-4mm thick)) I would be, up most grateful with any leads to obtaining 10pcs+..
Hi KJ6EAD, thanks for your response. I'll try your link,, but the photo doesn't quite do justice. The 7 Segment LED Display - Common Anode isn't shown clearly. Just to clear things up, the display is made of 3 separate 7 Segment LED Display Anode mounted next to each other... But thanks for your help really grateful :)
[Mod edited]
