Ariel Suero
Hello,
So I have put together the following circuit found in the link and everything with the regular part of the circuit namely, lights, switches, lock-out function all work.
I have wired up a common house-hold door bell which comes with it's own transformer to step down the voltage. And, I'm supplying power via it's own ACcord wired within a project both separate from the Game Show circuit. I'm using the small relay circuit to act as the door bell button.
Problem is it seems as though the capacitor maybe too large and is not discharging fast enough.
What I'm seeing after I press one of the game show switches is the corresponding light coming on, but with a slight delay the bell rings. However I'venoticed a hum coming from the bell unit when powered and connected to the relay circuit. It appears that piece that hits the bell plate is holding and then heating up when plugged in for a bit of time.
Can going from a 1000 uF capacitor to perhaps a 500 or 250uF help solve thedelay, the sticking of the bell striker? Any help would be greatly appreciated, I'm sooo close to finishing and this is the only detail holding me up..
Thanks!
Ariel
http://www.bowdenshobbycircuits.info/page7.htm#game1.gif
Thanks!
Ariel
