Help identify a power connector (socket)
Slick Willy
I'm trying to find the name/part # for for a smaller power plug/
socket. They appear to be used mostly for LED power cords, the plug
has two pins and a and a twist connector, the socket has two holes and
is threaded to accept the cap from the male plug. They come in various
sizes. The one I need had pins about 1/8" apart and 1/4" long.
These connectors are fairly new, any idea what they're called or where
to get them?
E
Eeyore
What's a "LED power cord" ?
Picture ?
Graham
Nigel Heather
I think I know what you mean - the type of connectors that you get in PC
cases to plug onto the motherboard.
They plug onto 0.1" pin headers, and consist of a plastic casing and two
gold plated connectors that you crimp or solder and push into the casing.
I've never seen them in any of the electronic stores I use but can find them
in shops that cater for RC models
3 Pin Type - normally used for servos
2 Pin Type - normally used for low power batters (e.g. receiver or
transmitter battery, not flight packs).
Here is an example of the 2 pin variety
http://ashtekelectronics.com/shop/bec-connectors-p29927.html
If this is right then others here will be able to point you towards a local
stockist.
Cheers,
Nigel
Slick Willy
stockist.
Cheers,
Nigel
No, it looks like the one in the bottom right hand coner of the TOP
picture in this link:
http://www.mainlandmart.com/pondlight.html
The one you can see is the male and the female is visible on the power
adapter in the background. The female connector I need is smaller with
a cord attached. They are used like coaxial power connectors (the plug
on the end of a wall wart), except that they are secure since they
screw on.
