Sir Revol . . . . . . . . . .
On small 12 in units like yours and on down to tablet sizes and digital display picture frames..
The PT4115 has been extensively used as a buck converter and LED backlight controller
Take this data sheet and initially note on page 2, that your unit is being in the left SOT89-5 casing profile.
Its sort of a wierd duck , IF you can' t see the back heat sinked side, without the unit being fully pulled off the PC board.
I refer to the page 2 where you see the pin #2 being its ground. What you wouldn' t know otherwise, is that is ALSO the SAME connection as the exposed tab that is marked up at the top of the chip.
I submit this pic of the other side for your examination.
PT4115 . . . Buck Supply and LED Brite Controller . . . . . . Heat sinked side
Now take out your ohmmeter . . .lowest scale . . . and just measure from pin 2 bottom up to that tab to confirm that connection.
Next go to the end of the data sheet and compare some of their design options to what components that you are finding on the board.
Looking at your connections on your pic, its a given to expect the RED and BLACK to be the power connections of the RED plug.
That is leaving the YELLOW to be the BRITE input info.
( In a foil path connection rundown, just see if you dont end up seeing YELLOW wire ending up being either directly or indirectly connected to pin # 3 DIM function.)
At the bottom, on the WHITE plug . . . . would be the power outputting to the backlight LEDs.
Your Pee Dee Eff Da-Da sheet hot link for the PT4115
https://people.xiph.org/~xiphmont/thinkpad/PT4115E.pdf
One of several sources for the chip:
https://www.aliexpress.com/item/PT4...32703389843.html?spm=2114.40010308.4.2.64NAcy
If all fails . . . .here is a Dual Driver . . .in case you have to buy a complete unit
( You could clip the power input foil leading into one unit to disable it . . . . if the other unit then being used, happens to fail , revert to enabling the other virgin unit, just waiting to be used.)
https://www.aliexpress.com/item-img...81824.html?spm=2114.10010108.1000017.2.3tkxsY
Thassssit . . . . . .
73's de Edd
