Help: how to design air-core transformer?
W
Winfield Hill
Jim wrote...
If I simply need a narrow-band transformer, e.g. 300MHz with
bandwidth>1MHz, what is the best method? I don't need continuous
tuning, so I can make a set of such transformers to cover the
range of 100-500MHz.
Ah, that's easy. You want a tuned impedance matching network,
or perhaps a tuned transformer, or a tapped resonator, etc...
http://en.wikipedia.org/wiki/Impedance_match
http://beradio.com/departments/radio_impedance_matching/
http://emclab.concordia.ca/~trueman/elec453/MW_Lecture_13_2004.pdf
And I did find an amazing report of a modestly wideband (15%)
50-ohm to 1-ohm transformer, working from 1200 to 1400 MHz.
http://ece-www.colorado.edu/~drc/eds/previous/mccalpin_4_03.pdf
One thing, keep in mind that 0.2nH of inductance is more than
0.5 ohms at 500MHz. Watch out. Do you know what you're doing?
Jim
budgie said:
It isn't clear (to me, anyway) why you are specifically seeking an air-cored
solution. What is the problem with a ferrite core? You can get a very good
match with a 3:1 turns ratio, or if you really want to get precise then increase
the turns so you get M:N ratio closer to SQRT(10).
I switch to ferrite core now.
Could you please tell me what is the upper frequency limit of ferrite
core? I heard from someone that the limit is 200MHz.
L
legg
Jim wrote...
Note also the links to course notes, transmission line and Z-matching
SW by Trueman at Concordia and Pozar at Amherst;
http://emclab.concordia.ca/~trueman/trline/index.htm
http://emclab.concordia.ca/~trueman/bounce/index.htm
RL
Rich Grise
The guy who made the core will tell you.
Good Luck!
Rich
