Spehro Pefhany
HAH!!! Joerg, you hit the nail on the head. This customer fully
believes that any other color circuit board besides BLUE will not work.
So, I agreed to supply blue circuit boards instead of green.
Two possibilities.
1) The guy really doesn't know what's going on, and is taking advice
from someone who doesn't know either.
2) The guy has already selected a competitive product (because he gets
a better kickback or his brother works there or whatever) and is
looking for a reason to give the work to them instead of you. The
blue board was his first attempt, and when you got around that, he's
trying this. This could backfire, but you could go to him and say
you think you've worked out a way to make the ground plane change
in time, and ask if there's anything else. If another goofy reason
pops up, politely run the other way.
OTOH, for thirty megadollars, you can get creative. Tell him you are
going to paint the bottom of the micro with a metallic paint to serve as
a ground plane, and add a contact for it to the board, or run a line of
paint over to the ground lead of the micro, or whatever. After the
board is stuffed, have somebody in production use a paint pen to draw a
silver line on the bottom outside edge of the micro - "overspray" from
when the bottom was coated.
Matt Roberds[/QUOTE]
One "tough EMC environment" product I was involved with even had a
stamped metal shield "ground plane" over the *top* of the QFP package.
Best regards,
Spehro Pefhany
