O
Oscar (X.)
I have to design a fast 10mbit/s FSK transmitter and receiver. The
frequency coding for mark and space can be chosen freely because the
transmission is between two very close electrodes (electromagnetic
coupling) and not across long distances in air. Actually I have some
design options:
1) ideally, a totally integrated solution (single chip which turns ones
and zeroes into the corresponding frequencies, and vice versa). But
I've been unable to find chips which were fast enough (I found
something like 300kbps at most).
2) I could use a PLL as a demodulator/modulator, but the TLC2933 is the
fastest I found (100Mhz max operating frequency) and I seriously doubt
that the loop bandwidth would be enough. Faster PLLs are usually
intended to be frequency synthesizers (for the implementation of clocks
and local oscillators) and there is no output pin for the VCO control
voltage...
3) probably I should find a PFD and a VCO separately if the integrated
solutions are not good enough
4) as a modulator theoretically I could drive a VCO directly, but it
must be suitable for that (fast frequency stabilization, decent
precision).
Do you already know about good ICs/solutions for this problem?
design options:
voltage...
precision).
