SIR josh1112 . . . . .
It appears that they are using two completely separate power supplies on your board. The larger yellow potted
transformer is probably just for your 24VAC for that approximate . . .or less . . . level of DC then created on the
board for relay drive by the 4 diodes in the PALE BLUE rectangle and the RED CIRCLE electrolytic filter cap.
If none of your 4 YELLOW circled indicator LED's PLUS the one near the right top corners transformer light,
that supply also probably serves them.
( ( ( With high probability that last green one, near the YELLOW transformer is a power presence indicator. ) ) )
The other isolated power supply for logic functions seems to be the BLUE transformer that feeds the BLUE electrolytic which then feeds into the YELLOW rectangle 5V 3 term Regulator 2, which may just use a pass transistor for pre reg 1 function or even just a zener diode .
The 5VDC then feeds the left top corners logic circuitry.
FAILURE ANALYSIS . . . . .high probability
Your electronics is probably still OK, with the end fault being related to time related attrition of the electro-mechanical aspects of the unit.
Look vewy-vewy-vewy carefully at the
GREEN / PINK rectangle marked up pair of motor direction reversing relays.
Each uses a single pole double throw configuration of its relay contacts.
Refer to the YELLOW arrow + dots going to he relay contacts.
I have
MAGGED this up such that you can now easily see that the right contact sets of the upper relay have been arcing to the extent that contact metal has transmigrated on up to the clear plastic cover and makes a quite noticable deposition of metal .
The same is true of the companion relay, just below it, but it has not yet degraded to that bad of an extent.
FACTOID . . . .
If these contacts reliability have declined to the extent of not always making positive contact a resultant paralleling or anti phasing of the AC motor windings can cause a hummmmm and groan of the motor and a popping of the fuse.
If done many times, the thermal protection within the YELLOW power transformer may have open circuited its primary winding.
INFO TIME . . for .feedback . . . .
How many fuses were placed in the unit and blown ?
Was the first fuse a soft or hard blow ? . . . a soft blow is where there is still a viewable fusing metal link inside.
A medium blow is where the opened link gap is wider . . . a hard blow is where there is even a blackening to the inside of the glass casing.
Would that be a 20 amp fuse ?
What info is on the actuator motor label , giving us relevance to its voltage, current or wattage ?
MORE INFO NEEDED . . . .
The capacitances and voltage ratings of the 4
RED BLUE and GREEN pairs of electrolytics.
Is REG 2 markings indicative of being a 7805 family of 5 V regulator ?
They may have "customized" the U1 microprocessor's ID by defacing its surfactal markings.
(BUT I think that it will not even be involved.)
Does this unit additionally use a key FOB type of remote transmitter ?
MAGGED UP COMPONENT SIDE BOARD REFERENCING . . . .
73's de Edd
