I am just trying to design a very simple CV sequencer using a 4022 chip, but would like some advice on how to proceed.
What i want to make is a very simple 8 step sequencer that outputs a voltage between 0 and 5 VDC, controlled by a pot for each pin, with a switch to disable each step.
I have an external clock source already, so i dont need to worry about that, just need to work out the best way of taking the output from the 4022 and turning it into a +5V-0 CV signal (doesnt have to be super accurate)
My understanding of the way the 4022 works (and correct me if i am wrong) is that with every clock pulse, each of the output pins goes to 5V+ sequentially, returning to 0 once pin 7 has gone high.
With that in mind, here is the first design i had:
I have only shown the parts coming from pin 1, the LED, switch and pot will be repeated for all the other pins, but this is just for illustrations sake..
will this work? my idea is that the pot acts as a voltage divider, and outputs between 0 and +5V to the CV out. Will it work in that position, or should it be between the LED and the 4022 pin so that when the rest of the pins are connected in the same way, their pots aren't connected?
My second idea is if the signal from the 4022 is not appropriate to use directly as CV:
here i just use the signal from the 4022 to trigger an NPN transistor, which lets the 5V+ through and then the pot is once again used as a voltage divider to give a 0-5V+ CV signal..
would it work like this? should i have the switch where it is, or would it be better before or after the transistor on the +5V line?
Also, for both of them, is it okay to connect the wiper from all of the pots to the same CV out jack? or should there be a diode somewhere stopping the current going back through?
sorry for all these, probably very basic, questions. I have a very basic knowledge of electronics and am just trying to piece things together myself..
If anyone has any advice i would be greatly appreciative, or any ideas as to how to do it better...
thanks
thanks
