W
Will
Ok, I'm pretty familiar with Layout so far and most of the parts I've
been using that didn't fit a standard footprint I've managed to kludge
together something that worked but I have a part that just will not
seem to work. The part is a 2SD2457 silicon NPN transistor from
Panasonic (got the datasheet from Digikey) and it has what Panasonic
calls a MiniP3-F1 package. Sort of looks like some of the voltage
regulators I've worked with in the past. Three legs across the bottom
of the chip with the middle leg blossoming out into a big fat pad
underneath the chip and sticking out slightly from the top of the
ceramic. So how the heck do I make the middle pad in Layout? It's
not a rectangle, and I'd rather not use my old trick of making two
pads and linking them together in the schematic. I tried making a
copper pour on the top layer of the board (it's a surface mount part)
and that mostly works, but the soldermask layer doesn't like copper
pours so I can't get it to mask that part off. How do I make
non-recatangular/non-oval/non-circular shaped padstacks that are also
masked in the top solder mask layer? Thanks for any help!!!
-Will
-Will
