Help calculating the resistors
Hi again everyone. The circuit you guys helped me with worked just fine.
Now I need one very similar, however smaller and simpler.
I already did the math to calculate the resistors, can someone just check for me if the resistance is correct?
Yes.
Edit: BTW, if you used high brightness LEDs you could probably run them at 5mA or less and have the battery last 4 times as long.
Bob
