jasen
I wind transformers too. If one winds the stator (non movable outside
part on my alternator) with more turns, the voltage will increase for
the same rotational speed.
We are talking about a DC electromagnet here - the rotating field --
magnetizing a hunk of cast iron (pole pieces). I ran some calculations
on wire size and cross sectional area of the coil. All things being
equal - same magnet wire insulation - the resistance goes up (as wire
gets thinner) the current goes down (greater resistance) but the
magnetic field strength stays the same if the cross section (filled
with wire) stays the same.
only if you can increase the voltage to compensate for the resistance
which increases twice - due to greater length and reduced cross-section
of the conductor. the extra turn compensate for only one of those increases.
annealed, and oxygen free, copper wire will have slightly loer resistance
but I don't think it'll be enough.
Bye.
Jasen
