Joerg
Question to the folks here:
I use more and more parts that have a ground pads underneath which is
also for extracting heat. Usually I ask the layouter to provide a big
via in the middle so I can reach in with a Weller ETS tip to unsolder
from underneath. I also let the pattern stick out a bit past the ends of
the chips so I can unsolder/solder from the top without always needing
fancy heat guns.
Occasionally I had some groanings from producrtion folks that this is
non-standard (which is true) and that the part may slide. Never saw any
of that in a reflow process, but what do thee all say?
fancy heat guns.
