Hello... need help. I have just bought some 40 mm 60 led rings.
What I would like is the name of the circuit or a diagram of the circuit of what I need to achieve.
So I have indicators that flash 12v bulbs and I have led rings that are on all the time. I would like the led ring to go out when the bulb is lit and stay on when indicators are off.
I can achieve this with a relay but is to bulky. Is there a simple circuit I can use instead. The system is a motorbike 12v 4 buld flashers control module. The 40 mm led fit in my indicators with clear smoked lenses. I have red for the rear and white for the front, so hopefully you can imagine what I want to achieve.
Thank you.
Thank you.
