I received the MAX232 chips today. i have put them to use and i get some weird resaults.
At the moment i do not have the GPS receivers to perform the tests but i only have the PC with the termite software to transmit NMEA data to the picaxe through the MAX232 like my last diagram.
I noticed that if PC is connected to GPS2 input (pin 8 of MAX232) the MAX converts the rs232 to TTL and the picaxe can understand the data and work's as desired.
When i change the PC from GPS2 input to GPS1 input (pin 13 of MAX232) and at the moment i attach the connector the MAX chip starts draining much more current and gets hot and gives no output.
After i remove power and allow the caps to discharge it works all right again (without any input connected).
With the PC connected to Both GPS inputs in parallel the problem again shows up.
