Joerg
Folks,
Just had a situation where a software toolkit could not properly handle
the sound chip in my Gammatech Durabook but it handled the one in the
Samsung NC-10 just fine. Anyhow, this is not cool if I ever have to
switch horses in the field because a laptop died or the battery ran low.
So ... what can you guys recommend as a good USB sound card?
It should:
a. not require a separate wall wart.
b. have a true stereo MIC input and if possible also LINE IN. But if no
LINE IN that can be ok. Main thing is I absolutely need two input channels.
c. be low in internal noise and not too suceptible to cell phones and
other common RF disturbances.
d. have an enclosure that's not too flimsy. Size doesn't matter.
e. preferably use a cable to connect to USB because the stick versions
break off easily.
f. ideally not cost more than $100 but cost is not too critical. So if
you know a really good one that is more I am still all ears.
g. allow easy driver loading, ideally right from that sound card.
It should:
break off easily.
