Sir tarheeldiver . . . . .
Looks like the found GENEVELAB model M of
Bluejets and yours don't agree.
With his being AC line cord powered
and
Your units, showing a need of a wall wart of 24VDC @1 amp with its
negative ground shell and a HOT center pin.
With his found unit putting out 100W audio
and
Your units, probably APPRECIABLY lower than that, with it ONLY having 24 Watts total DC input power.
With his found unit weighing 24 lbs
and
Your unit probably not weighing 24 lbs, with a bowling ball balanced atop it, on the weigh in.
At all considerations your only question is to find the EXACT power adapter for your use.
Don't think that's gohna happen ! what with . . .it being an ~ 13 year old, now discontinued unit.
The 24VDC @1 Amp wall wart specification is available , its just the snag of that
SPECIFIC sized terminating male barrel power connector.
Read my referencing below . . . . .
All of the barrel connectors you might possibly encounter . . . . .
https://www.google.com/search?q=mal...=img&ei=wM-AYZzpLpGctAXRwKl4&bih=969&biw=1920
What wiki says about it . . . . .
https://en.wikipedia.org/wiki/Coaxial_power_connector#RadioShack_Adaptaplug_conversion_matrix
The
MOST COMMONLY used connector sizes being found . . . .
In figuring the size of that internally positioned. male connector pin . . . . .
In my case I once bought a flea market find wall wart made by Radio Shack and it had 12 different connectors that would plug into ITS cable connector and have the other end, being a specific size end, plugging into the equipment.
I have no problems now, nor in the future in identifying a needed connector size, since I always KEEP that size of adapter and buy that needed replacement size, to install on the wart.
MOST likely you will be needing one of the two referenced
MAIN sizes, having a full barrel length and not a short / stubby sized.
Are you able to eyeball that internal pin connection and differentiate between a 2.1 and a 2.5 sizing ?
Or, can you get some side by side assistance, provided by placing a drill bit end inside, then being able to make a nose to nose to comparison between ?
73's de Edd . . . . .
IF A DEAF CHILD SIGNS SOME SWEAR WORDS . . . . . . .
DOES HIS MOTHER WASH HIS HANDS WITH SOAP ?
