Fred said:Ellombris-
NO. When the field needs to be flashed there is no output at all. If
there is ANY residual magnetism, there will be output, and almost
instantly it will build up to full value when you start the generator.
Something else is causing your problem.
Could it be the Idle Control switch is set to the "ON" position? That
would give your symptoms until you connect a load to the generator
output. If you connect a light bulb to the generator, does it light to
full brightness, or barely at all?
The diodes that rectify field current are in the module you replaced.
Unless it has an open diode, it is unlikely to be the problem.
When you installed the module, could you have connected the wires to the
brush assembly backwards? According to the Clymer manual, the White
wire connects to the positive brush, which is the one closest to the
bearing.
Fred
I removed the brushes and seated them properly, it seems they were
already seated OK. Changed the wires to the brushes opposite to how
they were hooked up, got 0 voltage. Reversed them and I get 65vac @
the 120 outlets and 120vac @ the 240 outlet. There's nobody local, but
I'm gonna try the closest to me, about 50 miles away that supposedly
works on generators. Otherwise this unit will be on sale on E-bay as is
to the highest bidder.
