Hi all,
I have never repaired a laptop computer before, only desktops.
Anyway, this motherboard has all signs of a bad capacitor (I can give all the details upon request, basically reboot loop with no post). None of the components on this board have any visible signs of damage.
Looking at this blurry picture (I can't get a good pic)...
1) are those power capacitors (the three columns of components with one missing in the upper right corner)? They are labeled pc234, pc 265, pc 266. so I am guessing power capacitors.
2) capacitors on a desktop have pins you stick into the hole and solder in. Do laptop capacitors just solder to the top?
I know this particular board is used for multiple notebooks, so obviously I don't know if there should be a third capacitor there or not. My guess is there used to be a capacitor soldered to the top of the two aluminum plates because of faints scratches on them, but I don't want to risk soldering one on there unless I'm absolutely sure there should be one there.
It's my sister's machine and she's not sure sure if a part ever fell out when she opened it after it broke. It was a few months ago.
3) Is there anyway to look up if a Gateway mt 6460 should have 3 capacitors in all three slots for a 31MA3MB00B1 motherboard?
Any help at all would be so much appreciated. I am an enthusiastic novice and I am even willing to ruin the board if I can learn alot from the experience.
Thank you so much...
