So if it's about ringing, why are they testing it at a clearly impractical
condition?
The appnote below only says: "durr, sometimes you need to slow it down
with RG, but then it runs hotter". None of their waveforms even solve the
problem set out in the title -- they all ring! I'm kind of embarassed by
that whole appnote, frankly -- a component manufacturer's engineers should
know the secret to quiet, efficient inverters by now. And it ain't
"minimize inductance".
At any rate, this doesn't answer my question: how do you implement a true
zero ohm gate driver? Are they just out and out lying? I wouldn't put
that past a manufacturer like International Rectifier, but TI?
For one example, I've never seen an IXYS datasheet showing RG < 0.2 ohms
or so, which happens to be around the output resistance of their driver
chips. Makes perfect sense, and it's practical.
Tim
Deep Friar: a very philosophical monk.
Website:
http://seventransistorlabs.com
Whoa, never seen that before.
That's because you are not familiar with the struggle to minimize ringing
in circuits containing these devices. The RG refers to the value of
damping bootstrap resistance in the gate drive circuit. Since it's
application specific they revised the original datasheet from RG 2R to RG
0R. The user will have to make his own determination of best RG.
http://www.ti.com/lit/an/slpa010/slpa010.pdf
