Hi, I have a Garmin 4008 GPSMAP unit. It's a beautiful bit of gear, and with depthsounder module and transducers, cost about $3000.
Problem. when I turn it on it will run for as long as I want, If I turn it off, It will not restart and Takes about 20 minutes to cool down to where it will turn on.
Normally draws 1.4A, 12V and the boards run at 7. 2V and 5.08V very stable. The 5.08V runs a second cooling fan , the map system and switches (on/off, and all settings).
When the problem occurs and I switch on the 5.08 volts becomes 2.2v and power in drops to 0.27A (a fan on the power board turns on).
I believe I've tracked it down to a capacitor (ceramic, 16V,470, 105 degrees C). When I spray freezer on that cap, the voltage comes up to normal and the rig starts. I changed the cap and now it is not so bad,but will not switch on for a couple of minutes. If I leave the case open, this stops the problem.
Any ideas, should I use a different cap?
Garmin Australia won't look at it and says I should bin it and buy another (Garmin!)
Won't give circuit diagrams.
I told them that is like taking my 2012 favourite car and pelting it when the problem is a spark plug???????
Any advice?
Les
Any advice?
Les
