Garage Protection with Pets
F
Foo Bar
Another newbie question here.
House is a combo wired/wireless with an Ademco 20P panel. I have a
problem protecting the attached 2 car garage. The main garage door, the
door to the house and the back door are mag contact protected. The
problem is that we have cats and sometimes want to bypass the back door
to let them go in/out while away for a short time. Thus I need some sort
of "space" protection to pick up someone who may enter via the
bypassed/open back door. I first tried an Aurora PIR mounted just below
the open rafters. Unfortunately, with small cats, if they climb into the
rafters, they are close (and hot) enough to simulate a 40lb critter. I
pulled the Ademco and replaced it with a microwave/PIR combo unit. Much
better but still managed to false once. I guess I could be very careful
in locating the PIR and masking out the usual location that the cats
might be in, but I am hoping one of the pros can suggest a more
cat-proof volume protection sensor.
-Bill-
Crash Gordon®
I believe the 20P can use cross-zoning, although I've never done it with this particular panel. You install 2 motion detectors in one area, then program them as cross-zoned with each other. A trip on one will not cause an alarm unless the other one also trips within a certain time frame (usually programmable in the panel). Then with a little creative pir placement you're all set.
F
Frank Olson
I am hoping one of the pros can suggest a more cat-proof volume protection
sensor.
..357 hollow points. Best "cat volume protection" around... :))
F
Foo Bar
Hi Crash;
I did a quick scan of the manual and didn't see any zone type that that
used 2 triggers to alarm, but my reading wasn't real complete. I suppose
I could put in 2 detectors in a NO loop to effectively AND the signals.
The downside is the on time of about 3 seconds would require the
detectee to move through both detectors at about the same time. Thanks
for the idea, I will look into using a small microprocessor to do what
you suggest to combine multiple sensors with a time window.
-Bill-
Crash Gordon®
Don't AND them, not reliable - there was a lengthy discussion on this a month or so ago.
Lemme find a V20P book, I could sworn I saw it in there.
Crash Gordon®
Ok...never done it on Vista stuff... so..bear with me,,
*85 field is where you set the cross-zone timer
*81 is where you set up the Zone List...it looks like List 4 is where you set the zones to be cross-zoned.
Read the *Install* Manual you should be able to figure it out from there.
Crash Gordon®
....oh yeah...switch to my combat commander with hollow points or snake shot.
Paul Ekins
I know of a French idiot who used a .22 to rid his house of a mouse. Only
problem was it took him 7 shots and it was in the kitchen.
F
Foo Bar
Crash;
Thanks much for the fast reply. I had missed the cross-zone stuff since
it was in the zone list, not zone type.
One question comes up, I am adding 2 PIR/WW sensors (zones x and y) that
will go into zone list 4 (cross zones) The manual indicates that the x
and y zones must be type 3, 4 or 5 (perimeter burglary, interior
follower or day trouble/nitght alarm)
Since we go into the garage when the alarm is armed stay, modes 3 and 5
don't work as we would trigger the alarm. Mode 4 works, but would cause
an instant alarm if armed away. Mode 10 (interior with delay) is my
preferred mode but I don't know if it would work (problem with
conflicting timers). Any suggestions?
Thanks;
-Bill-
F
Foo Bar
A rural friend tried to plug a raccoon in his house with a Glock/.40SW
The coon survived, the repairs were, shall we say, costly.
Crash Gordon®
I'd use as an interior follower (4).
Interior with Delay should work too, what do you mean conflicting timers(?) [again I didn't read it all so you may know something I don't] you could set it to use second entry delay time too.
| Crash;
| Thanks;
| -Bill-
| >>Hi Crash;
| >> -Bill-
| >>>> -Bill-
alarman
Crash said:
I prefer 6mm, nice flat shooter good fer vermits.
Too risky. I'd use a wrist rocket and a sack of walnuts. Those bad boys make
an "impression" on kitty, even if they miss.
js
Crash Gordon®
why am i not overly surprised :))))
| | > In the garage??????
| > -Bill-
| > >>Too big, a 148 grain HBWC in a 38 special and light powder would be a
| > >>better choice. But then who would star on the CatCam?
| > >>http://www.rtcatranch.com/index_007.htm
| > >> -Bill-
| protection
| > >>>>sensor.
Crash Gordon®
Walnuts?
Interesting idea.
| js
F
Foo Bar
The notes section on zone programming says when creating a zone list 4
"do not include zones that have delays (entry/exit zones, interior
w/delay) or 24-hour zones as these zone types may produce unpredictable
results and may not function as intended"
I made the assumption that the small microprocessor used for the panel
may only be able to track 1 or a limited number of timer events
simultaneously. It may not be able to do the cross-zone timing while it
is doing an entry delay even if 1 triggers the other. It looks like
experiment time!!
-Bill-
| Crash;
| Thanks;
| -Bill-
| >>Hi Crash;
| >> -Bill-
| >>>> -Bill-
