Push pull drive would work, and work well. But, believe design I've
got in mind will be ~ $1.50 lower part cost. Target production volume
definitely high enough for part cost savings to pay off R&D labor.
In fact, had rather hoped that target volumes would be high enough so
that we could sweet talk vendor into making up an eval lot of cores
with assorted gaps "bracketing" intended AL value. Will still pursue
this, but, vendor is in Far East; they make good cores, and they make
them cheap, but they have not generally given us very good lead time
for prototype lots. So, thought I would try "fiddling" gap in our lab,
then giving gap spec to vendor for production order. May try Dremel
tool; do worry about cracking core!
W Letendre
Silly rabbit! You buy some UN-gapped cores, and use fish paper to
achieve the right gap. Remember that when gapping the entire core as
this paper gap process does, you have to double that gap value when you
go to order the properly tuned (gapped), gapped core.
Instead of paying for a set of cores with incremental gaps, you should
get un-gapped core sets, find out what your gap needs to be by gapping
the entire core (inner post is one path, and the outer ring is the
other)(note how the surface area of the outer ring is the same as that of
the center post). Then the gap you order is a mil or two less than
double the paper gap tuned figure. That way, you can have it closer, or
do some fine, flat plate abrasive sanding on the center post (the dremel
is a BAD idea) to make changes. You can easily pull off a mil or two or
ten, if you wish with the flat plate method.
Your proto tuning point which you arrive at should transfer over well
to a center post only gapped cores set, where you take a single, non
gapped core half, and mate it to a core half that you have had gapped on
the center post. You would double the gap you used in the proto session
to get the gap thickness you would order from the core presser. They
usually remove the media abrasively.
You can buy 1 mil (fish paper) or find "Nomex" high dielectric
transformer paper (that's the brand you google for), which comes in
precision thicknesses. Try Farnell for a source.
You can get a mil, 1.5 mils (important for making half steps),
2 mils, 5 mils, and ten mils in thickness, and I'll bet that they would
send you a sample pack. With media like this, you can buy un-gapped
cores and gap everything yourself, as this paper keeps its physical size
well, even after impregnation. (I had to use "the I word" :-] )
You can also use transformer tape to gap with for lab proto, as it
also comes in precision thicknesses. A razor knife edge trims
transformer tape excess well.
