Gadet Geocache - lock not tripping
Hi All,
I'm trying to build a gadget Geocache, where when you complete a puzzle it opens up the container. I've mounted six reed switches on the underside of the container and recessed six magnets into the bottom of the puzzle pieces. The switches are cabled in series with the lock and a I'm using a 9v battery as a power source.
It worked when I test fitted everything together but now I'm running into two issues. One of the reed switches failed, it got very hot and the plastic housing expanded, so I'm assuming some type of electrical failure. Also the lock does not open when the puzzle is completed, it clicks but does not open though if I apply the battery directly to the lock cables it will.
Any help or pointers would be greatly appreciated.
Many Thanks
Reed Switch Spec
Lock Spec
Wire Spec
After having a quick look at the specs, The reed switches have a max switching current of 0.5A. The lock draws 1.5A.
That could be your problem.
Besides that, the lock is also 6V and you are supplying 9V.
Martin
Martin
Thanks, I think I have a holder for four AA batteries, that would give me the correct voltage. Do I need to add some resistors or other components to solve the amperage issues?
If you lower the working current of the lock, it wont operate properly.
Probably better to get higher amperage switches or lower amperage lock.
Edit: You could try and see what the lowest current the lock will work on.
Martin
Martin
Thank you for your help so far. I've tested the lock by using 1,2,3 and then 4 AA batteries it would only open when using 4 AAs. Would 2amp switches suffice like these?
You might want to think about using the switches to feed into the gate of a MOSFET.
That would solve all your low current switch issues as well as the high current latch problem
I draft these things in LT Spice, so some parts look odd (its a simulator, not an illustrator)
but your application will look a bit like this.
standard issue 1n4003 diode should work .... MOSFET ... IRLZ14 is my random stab at it for about a buck each.
I'm sure others have other go to N channels that'll do just as well
