noobie here .. my function calls are giving an error that its not defined in this scope
#include<SoftwareSerial.h>
#include <NewPing.h>
#define TRIGGER_PIN 12 // trigger
#define ECHO_PIN 11 // echo
#define MAX_DISTANCE 200 //dist
SoftwareSerial myserial(9,10);
NewPing sonar(TRIGGER_PIN, ECHO_PIN, MAX_DISTANCE); // NewPing setup of pins and maximum distance.
int input1;
int input2;
int input3;
int timer1=1;
int timer2=1;
int timer3=1;
int timer4=1;
int depth;
void setup()
pinMode(2,OUTPUT);
pinMode(3,OUTPUT);
pinMode(5,OUTPUT);
Serial.begin(9600);
myserial.begin(9600);
void loop() {
input1=analogRead(A0);
input2=analogRead(A1);
input3=sonar.ping_cm();
Serial.print("input1=");
Serial.println(input1);
Serial.print("input2");
Serial.println(input2);
if ((input3>13)&&(timer1=1))
empty();
timer1=timer1+1;
timer2=1;
if ((input3<100)&&(timer2=1))
full();
timer2=timer2+1;
timer1=1;
if(input1<500)
digitalWrite(5,HIGH);
digitalWrite(2,HIGH);
timer3=1;
else
{ digitalWrite(2,LOW);
digitalWrite(5,LOW);
delay(500);
if(timer3=1)
SendMessage();
timer3=timer3+1;
if(input2<500)
digitalWrite(3,HIGH);
delay(500);
timer4=1;
else{
digitalWrite(3,LOW);
delay(500);
if(timer4=1)
SendMessage();
timer4=timer4+1;
void empty()
mySerial.println("AT+CMGF=1"); //Sets the GSM Module in Text Mode
delay(1000); // Delay of 1000 milli seconds or 1 second
mySerial.println("AT+CMGS=\"+919035349750\"\r"); // Replace x with mobile number
delay(1000);
mySerial.println("Alert..your water tank is EMPTY");// The SMS text you want to send
delay(100);
mySerial.println((char)26);// ASCII code of CTRL+Z
delay(1000);
void full()
delay(1000);
mySerial.println("Your Water tank is full..\t Please turn off the pump");// The SMS text you want to send
delay(100);
delay(1000);
void SendMessage()
delay(1000);
mySerial.println("Your garden has been Watered just now");// The SMS text you want to send
delay(100);
delay(1000);
int input1;
int input2;
int input3;
int timer1=1;
int timer2=1;
int timer3=1;
int timer4=1;
int depth;
void setup()
pinMode(2,OUTPUT);
pinMode(3,OUTPUT);
pinMode(5,OUTPUT);
Serial.begin(9600);
void loop() {
empty();
timer1=timer1+1;
timer2=1;
full();
timer2=timer2+1;
timer1=1;
if(input1<500)
timer3=1;
else
delay(500);
if(timer3=1)
SendMessage();
timer3=timer3+1;
if(input2<500)
delay(500);
timer4=1;
else{
delay(500);
if(timer4=1)
SendMessage();
timer4=timer4+1;
void empty()
delay(1000);
delay(100);
delay(1000);
void full()
delay(1000);
delay(100);
delay(1000);
void SendMessage()
delay(1000);
delay(100);
delay(1000);
