GPG said:
I would say not.
The 40Hz comparison frequency is too low. That's going to force you to use
a very low loop bandwidth, which will make it slow to lock.
You'd probably need to convert the mixer inputs to sine waves first; and
it'll produce sum and difference products, so you'd need a good low pass
filter to remove the 10.4-13 MHz sum product whilst passing the .4-4 MHz
difference. Finally, you'd need to square-up the sine waves again before
feeding them to the dividers.
If the aim is to produce low frequencies with high resolution, how about a
DDS?
If you want a PLL with small steps, consider Fractional-N.
