Hi i am after a schematic for a frequency/waveform generator. Adjusable frequency and amplitude for sine, square and ramp. Upto 100KHz.
Something which is easy to build.
Any ideas?
I have but some use obsolete parts. I was looking for a quick, cheap and easy schematic. That can be knocked up with readily available components. Dont need any microcontroller type.
If you want low distortion, particularly with the sine output, and a frequency range as wide as that the circuit won't be quick, cheap or easy unless you use a digital (microcontroller) approach.
How much distortion can you tolerate?
What voltage and current requirements do you have?
