Just a few musings about this topic:
The first thought that crossed my mind was how could I employ this technology in my machine shop work. Sadly I can't think of any but at mere 10 microns displacement I don't think I'll ever be able to produce a part with tolerances that tight anyway.
My second thought involves the purpose of this project. Statements made by shibas leads me to believe this is a class assignment. It has the classic paraphrase "I need this fast" in his second post. The second dead giveaway is found in his third post ..
I think we can design these dc power supplies using a transformer,a bridge rectifier and a capacitor.
This reprises a dilemma that we often have... How much information do we divulge without actually doing the student's home work for them? After all, when I was teaching I did give credit for the ability to research.
Number 3 on the musing chart are the power supplies. Without actually doing your home work for you here are some thoughts that you can expand on. When vacuum tubes ruled the roost it was common to find HV resistive voltage dividers.used where very little current was required from the node being tapped. Since this Stack Piezo is primarily capacitive I see no reason why a low current 3 tap voltage divider wouldn't work.
Here's a cheap way of making a 1:1 isolation transformer (Macro) that can be safely connected to the mains. Though 240VAC to 12VAC transformers are indicated they can be 120VAC to 12VAC as well. At 120VAC input it will output about 169VDC when filtered. This is more than enough to feed the voltage divider I described.
For those of us that are nostalgic for most things old I still own this Heathkit since sometime in the late 60s or early 70s. The Cap/Leakage test has a range of 3VDC to 600VDC, which is facilitated by resistive voltage divider connected to the rotary switch on the middle right side of the instrument.
http://www.ebay.com/itm/NICE-VINTAG...ultDomain_0&hash=item589e48ff0f#ht_2373wt_679
Chris
