Hi guys,
I've been trying to diagnose my wife's dead food mixer without much success. The problem is probably the power supply as I don't get any LED's or sign of any life whatsoever. The mixer is only 18 months old but out of warranty. There are two PCB's; the larger one contains mains input and the TRIAC that goes to the motor. On the same board there is a low voltage side which I assume provides the TRIAC regulation. There is a separate small PCB which houses a switching transformer circuit. The filtered mains goes via two cables to this small board, then returns to the main board via three low voltage cables after AC rectification and small switching transformer. When powered up, I'm only getting 0.3v between the low voltage connections on the small board. I've had most of the components out and tested them. The inductor was blown, and the Schotky diode was blown. The transformer, optocoupler and capacitors are good. The small IC on the under side (I assume) is some kind of PWM or regulation but it's not labelled. I still think the issue is with this board.
Why is there three cables returning to the main board from the small board and not two? What voltage would it likely be producing? The transformer has a label 13 - 2.5 mH. I might be able to buy a replacement board if I knew what this board was putting out.
I've attached some photos of the boards.
Any help appreciated. - thanks in advance.
Andy.
Andy.
