Your are welcome,
This is what we do here, help![]()
And for that I am extremely grateful!
I have carried out further testing, and the results are below:
We can go on finding the fault.
First thing is to check the DC voltage on DZ1,
12VDC expected,it should be present both in the ON an OFF states.
What do you get?
DZ1: ON = 12VDC, OFF = 12VDC
Then check the DC voltage on DZ7,
12VDC expected in ON state,0V in off state.
What do you get?
DZ7: ON = 12VDC, OFF = 0.45VDC
Then check the DC and AC voltage on R24,
12V to 0V is expected in all states and speeds.
What do you get?
a total of 10 measurements: 5 for DC,5 for AC( in 3 speeds+pulse+off).
R24 (SP = Speed, P = Pulse):
VAC: SP1 = 7.8, SP2 = 7.8, SP3 = 10.2, P = 10.2, OFF = 0
VDC: SP1 = 3.7, SP2 = 3.7, SP3 = 4.8, P = 4.8, OFF = 0
There appears to be a slight difference between SP1/2 and SP3/ Pulse. Voltages rounded up as the figures fluctuated slightly to the right of the decimal point.
N.B. the "Speed" settings on the processor are as follows:
SP1 = "Dough"
SP2 = "Slice/ Shred"
SP3 = "Chop"
Pulse = Motor runs for as long as the "Pulse" button is held down. It allows the user to manually "pulse" the food processor motor.
Off = Self explanatory
How do these figures look? Are they what is expected? Though there are differences in voltages between the speed settings, when the motor runs it sounds exactly the same whatever speed is selected. I assumed that if it's actually running as intended, there would be a more noticeable difference in motor speed. I could do with an RPM meter to find out for sure!
