Meat Plow
Thanks for the continued input everyone. Most recent developments: I
again tried the Win 7 on my new SATA, but with a known-good PSU, and it
froze in about 15 minutes. So it's not the PSU. After this, I loaded a
32 bit copy of XP Pro on an IDE drive, and the machine has run for about
4 hours without a freeze (I should add I loaded Win 7 previously on this
same drive, and it froze like it did on the SATA). During the time the
machine has been running fine under XP Pro, the PC has been surfing the
internet on one monitor, while continuously playing .VOB videos on VLC
with the audio muted on a remote plasma (like the older build this one
is to replace, I use the computer for general PC use as well as for a
HTPC), while also playing a 2 hour MP3 on Winamp. One possible
conclusion from this that either the PC, or the video card, does not
like 64 bits. Reading the reviews of the board on Newegg, many people
seem to be running Win 7 64 bit with no problem, so I'm guessing it's
not that the MOBO has a problem with that OS. Am I correct that it would
be unlikely for either the RAM or the CPU to be intolerant of 64 bit Win
7?
BTW, ran Memtest for ~ 3 hours. No errors.
I'm considering replacing the vid card, since it seems a very likely
suspect. I'm not a gamer (though this gear should be up to it), so I
don't need anything tooooo drastic (read, EXPENSIVE). As JL suggested,
I'm wondering about the PCI E 2.0 slots. Also, I've been using a X16
slot (MOBO also has X8 slots). Could the Vid card be the culprit? And
opinions on this card for my applications:
http://www.newegg.com/Product/Produc...82E16814131350
Thanks again for the replies!
Dan
Look for an EVGA branded GeForce 9500 series.
