Harveyx said:...
Uncle Al overstates his case a bit.
Why dont we try numbers instead of words..............
Forget 'mode structure' for most N2 lasers, there is essentially none, they
are single pass. But neither is it *quite* 'a flasbulb'.
To a pretty good approximation crude nitrogen lasers have a divergence
which is about d/L where d is the 'tube' (discharge, often transverse)
diameter & L the length.
If you focus it with focal length F your spot diameter is just F*d/L
So, if you want 0.1mm, d is maybe 5mm & L maybe 200mm you would need a 4mm
focal length, which is operating at F~0,8
You might get a UV transparent microscope objective (at a price) that gets
near that, but its pretty challenging to put it mildly.
With a longer, thinner laser, and relax it to 'a few' hundred um spot, and
you would get into just about achievable regimes.
With longer focal lengths, the F number falls, & aberrations are rapidly
less of an issue - its rather far from diffraction limited!
Lens UV transparency at 337nm is an issue, especially for a thick short
focus lens.
Harvey
For these homemade nitrogen lasers the tube is just filled with air
and made of transparent plastic, so is quite cheap. Then you could have
a tube length say the full length of your basement, say 10 meters,
10,000mm.
Then for a diameter of 25mm, you would only need a focal length of
40mm to get a spot diameter of 0.1mm. How are 40mm focal length, 25mm
diameter UV lenses pricewise?
Bob Clark
