Foam cutter,load
Hy
I am going to make foam cutter,for cutting stirofoam.
12v at 2 amps,with led dimmer to adjust temperature and with high resistance wire.
The question is do i need a load,some bulb,to not fry my power adapter.
You need a contollable current source. A 'LED dimmer' may or may not offer a well-controlled current. A schematic or link to its spec would help to determine its suitability.
It won't offer well controlled current, it will deliver a PWM signal. That should be OK for heating a wire. The wire should have the correct amount of resistance to act as the load. For 2A at 12V the resistance is 6Ω.
Bob
Will this do,
So if wire can handle the resistance it won't damage the power
