I know very little about electronics though I'm fairly handy and have
experimented with some simple circuitry. My objective is to build a
water level sensor for a 10 gal stainless steel kettle that's too high
for me to see the fill level. My idea is to build a panel using LEDs
to indicate how many gallons are in the kettle as I fill it. My
thought is to place a device(vertical stick) with bare terminals at
specific levels plus a common wire on the bottom. Thus as the level
increases, the water completes each circuit like a switch and lights
an LED indicating each gallon level. My concern is the resistance of
the water. Obviously it would be low voltage so I don't think I need
to be concerned about a shock. Do you think this could work?
Thoughts?
Thoughts?
