I've been doing a little digging online and on the forum and found some basic circuits that utilize a Diac and a Triac to control a load. The Diac/Triac combo is triggered by a very basic RC circuit that usually has a potentiometer/trim-pot in series to adjust the timing that the Diac/Triac fire.
My question involves adding feedback. Instead of being able to adjust the output from 0-100%, I would like to adjust the output temperature. A temperature probe would adjust the timing to fire sooner when the temperature is too low, and fire later when the temperature is too high.
The example circuits I keep finding are attached.
Is what I'm trying to accomplish as easy as connecting a variable resistive temperature sensor to the RC timing portion of this circuit? I don't like the idea of having 110 or 220 on a temperature probe.
I would also like to avoid using a microcontroller and stick to some good ol' fashioned discrete components, but would like to avoid the temperature regulators you find on cheap waffle irons...
Tips, tricks, suggestions, or research topics are welcome.
