G
George Herold
So following a comment by Mikko that ferrites stop working when cooled
to liq. helium temperatures. I ‘discovered’ that ferrites have a
phase change somewhere near 120 K. (at least magnetite does.)
Google “Verwey transition”
Wiki is mostly silent on the subject though there is a bit here.
http://en.wikipedia.org/wiki/Charge_ordering
So first I’m a ferrite novice. I’ve wound some RF transformers in the
deep past, but that’s about it.
I found that I could measure the resistivity of some ferrite beads
with just my DMM. I’ve got two types of bead the 43 material and the
73 material. The reported resistivity’s are 43 = 1E5 ohm-cm and 73 is
100 ohm-cm.
I made a little jig to squeeze the beads in. The brass screw has a
cone turned on the end.
http://bayimg.com/FAcKEAAeE
So first off there seems to be a huge variation in the piece to piece
resistivity. At least an order of magnitude in the few pieces I
looked at.
Second the resistivity was (most of the time) much higher than the
reported numbers.
1E6 to 1E7 for the 43 material and 3E3 to 2E2 for the 73. (The 200
Ohm-cm for one piece of 73 was about right.)
And finally the 43 material was some older stuff in my parts box. I’m
not quite sure of it’s provenance. So I got some new pieces out of
stock. For the new material I couldn’t measure the resistance with my
setup. I even biased the bead from a 30 volt supply and used the
10Meg of the DMM as a voltage divider... I could measure a 1 G-ohm
resistor that way, but not the beads! resistance greater than 10 G
ohm or os.
I’m wondering if anyone has some more in depth knowledge they might
share. The ferrites look like they might be a ‘model system’ for some
new solid state experiments. Besides looking at the Curie
temperature the phase transition at 120K shows a peak in the heat
capacity, change in resistivity and magnetic properties. What could
be better!
Thanks,
George H.
100 ohm-cm.
looked at.
reported numbers.
ohm or os.
be better!
Thanks,
George H.
