ferrite or powder iron?
Y
Yzordderrex
I need to build some inductors for elliptic low pass audio filters.
The values are near 0.004H and 0.007H. The output impedance is about
100ohms and the voltage level is about a volt or so. So in other
words the current is in the area of 10mA. The parallel capacitance I
have to put across the inductors is fairly high so that winding
capacitance probably doesn't matter at all. I can use lots of turns.
My options as I know them are a higher permiability power iron or a
ferrite part. Would one material be superior to another? I've got
some lower permiability ferrite cores and also some small gapped EE19
ferrite coresets with about 200nh/t^2. I also have some good sized #26
powder cores.
Project is for one homebrew audio filter for ham radio and will not be
mass produced.
regards,
NEO
E
Eeyore
powder cores.
mass produced.
Ferrites saturate too quickly for this application. Powdered iron is the way to
go ( lower u ).
Graham
E
Eeyore
powder cores.
mass produced.
Oops, I misread you.
You can use ferrites for that.
Graham
John Popelish
powder cores.
mass produced.
I think I would work with the gapped ferrite cores,
especially if they are a power material (high saturation
flux). These are pretty linear (by virtue of the gap) and
low loss at audio frequencies. The powdered iron #26 cores
are just distributed gap cores, but the iron material
generally has more hysteresis loss than ferrite. I usually
use #26 for DC energy storage choke uses.
E
Eeyore
I looked up some data on them. The MMP cores are *very* nice with little change
in permeability with working flux.
Graham
John Popelish
I was under the impression that mix 26 was not an MMP
choice. Am I mistaken?
E
Eeyore
You're not mistaken. I can see how my post could be misread.
I looked at some comparison data and I was just commenting on the additional
linearity of MMP cores.
Graham
Y
Yzordderrex
use #26 for DC energy storage choke uses.- Hide quoted text -
- Show quoted text -
Ok, thanks guys. The gapped EE sets are 3C90 from small flyback
transformers that I designed for the boss. They are small, free, easy
to wind and mount so I'll go with those.
regards,
Bob
E
Eeyore
Get yourself Epcos's Ferrite Magnetic Designer program. It's damn useful and
free. It'll do the calculations for you.
Graham
Terry Given
Graham
apart from the fact its MPP (I'm a pedant), you're right. then compare
the cost. -26 is ~ free, MPP sure aint. Koolmu is likewise - great and $$
Cheers
Terry
