Albina said:
Now here's the deal...
I found two crappy joints and redid them (although I'm sure there are plenty
more, if not all of them; I'm new to this stuff). Now, I can plug my guitar
into the input, and plug the output into my amp. I turn the amp all the way
up (2 12inch speakers running at 115 watts) and all I get is this really
weak ass signal that sounds like a clean guitar. Where's my clipping!? And
why's it so damn quiet!?
Thanks for all the quick support so far.
I would trouble shoot this way:
First I would measure the voltage across the supply rails of the
circuit, to make sure the battery was good and connected through the
input plug to the rails.
I would connect a .1 uf capacitor to the hot terminal of an extra
jack, and connect the ground end to the ground of the circuit. I
would plug the amp into this jack (with the volume turned down low),
and use the other end of the capacitor as a signal tester.
Set all the controls to mid point. Start at the input plug and verify
that the guitar comes through cleanly, there. Then move to the output
side of the first transistor, then the next, etc., verifying each
stage from input ot output. At each stage the volume should either be
louder or more distorted. When you find a node that has much lower
volume than the previous one, you have just jumped over the problem.
You may be able to find the problem by inspection, at that point.
By the way, I hope you didn't solder this circuit with acid core
solder or use plumbers soldering flux paste. These conduct
electricity and partially short any two nodes the flux bridges.
