Joerg
D said:Hi Joerg,
Yes. Find a battery holder that someone *else* has incurred
the cost of that molding! Preferably, something that lets
the user access the "battery compartment" without having
to disassemble the device itself.
Very tough. I had tried that at times in the past and there ain't much
out there. Even the ready-to-go enclosures with built-in compartment
that I came across aren't really good in that respect.
OTOH, if he is making "one off", a bit of plastic glued on either
side of the '+' holder terminal can do the trick.
I'd also look for those (camera?) batteries (two cells side
by side... 3V?) as I think that is keyed (at the very
least, it eliminates the problem of putting one cell in
correct and one backwards)
I have one, in case of a trip way into the boonies (those are Li
batteries so they'll last longer). Very expensive, not really an option
for everyday use.
Very easy: Oscillator that is connected via a diode so it works only
when batteries are reversed, drives piezo. Battery inserted the wrong
way -> beep ... beep ... beep ...
If you want to also cover the case where only one of the batteries is
reversed use two of those, can drive the same piezo.
You don't need to be that extravagant. Just something in the
*normal* usage of the device that people can count on for
feedback/confirmation. E.g., if the device uses audio
output (synthetic speech or just "tones"), then design
the device so that immediately on turning on, it "chirps"
once.
[I don't recall what he has chosen for his output medium;
personally, I would opt for limited vocabulary speech as
it can be *very* small]
This gives a positive indication to the user in *normal*
operation (i.e., those times when you HAVEN'T just
changed batteries) that the device is, in fact, "on".
And, knowing to expect this, it can be used when replacing
batteries to act as a confirmation that the batteries
are, in fact, installed correctly, aren't "dead", etc.
Yes, that's usually good enough. No audio feedback -> something must be
wrong with the batteries.
