Si Ballenger
74HCT259
I was using LM324's in the 1977-1987 time frame. I had three basic
ICs that I used, LM324, LM339 and TL084, plus logic. I could build
*anything* ;-)
...Jim Thompson
Jim said:I was using LM324's in the 1977-1987 time frame. I had three basic
*anything* ;-)
The crossover distortion of the LM324 never bothered me because one
could just bias it for class-A operation if that were a problem.
Its real Achilles heal, IMO, is its strong propensity to rectify
impulse and RF noise on its inputs. This can be somewhat ameliorated
by putting small capacitors (especially surface mount) physically
right across the inputs and/or to ground, but why bother the 324 at
all when this added cost and trouble sort of defeats the purpose of
using such a cheap opamp in the first place?
Agreed, with cars !-)
Stefan Heinzmann said:And there are applications where cost is all that matters. Or does
anyone know of a quad opamp that is cheaper than the LM324?
There's a function generator of far-east brand on my bench that is built
using a fair number of 324s, discretes and CD4051s. It goes up to 10MHz,
although above 1MHz the results aren't very convincing. Still, kudos to
the designers for squeezing this out of such a poor device.
N. Thornton said:What part does a 324 have in a 10MHz machine? Feedback stabilising? I
cant believe it could do anything at 10MHz.
and women. ;-) ...unless the wife is near.
John said:How do you mean "as intended"? National's original datasheet (9 sheets
of it!) shows lots of examples where the output is DC unloaded, and
will have lots of crossover distortion.
With a large-signal frequency range of 5 KHz, it's nowhere near "as
good as any 1MHz GBW opamp".
Winfield said:Jim Thompson wrote...
Accckk, LM324 and active filters in the same sentence?!
Have you no shame?
As long as the instantaneous sink current is less than 50uA (plus
error margin), there is *no* crossover distortion.
Paul said:Hopefully in the same package!
I heard it will only be available in BGA soon. ;-)
Well, perhaps nothing that draws more than 50 uA, which covers a LOT ofThat sort of says that it's an OK opamp as long as its output is never
connected to anything. Agreed.
John Woodgate said:I read in sci.electronics.design that Chris Carlen
.... supplemented by an octal-based version for real men.(;-)
V
V
V
V
V
V
V
8 pins not enough?
It has a base at each end of the package. Or six top-caps.
