This "coil" is an EMI (Electro Magnetic Interference) line input filter.
It is used to filter out(with the surrounding caps) the noise created by the SMPS(Switch Mode Power Supply) from reaching the line.
The "coils" have different configurations and specific values,you need to know the manufacture and part number to get an exact replacement.
The "coil" from the other SMPS may work.
The minimum requirement is same diameter wires.
But!
A failure of the "coil" needs further investigation since most likely it is a cause ofover current in the SMPS (unless it is a mechanical failure like creak or broken leg etc.)
So,
What is the coil's failure in your case?
Was the fuse intact?
Lastly,
Here is a catalog of line filters from Murata .
You can see various configurations an ratings.
But!
So,
Lastly,
