Hi all,
I have a few LED spotlights that are constantly flashing on and off. From experience I know this normally means a faulty power supply so I pulled one apart and the power supply is very small (62MM x 30MM) and the input is 100~240VAC and the output is 9VDC feeding 7 1W LED doides (2 red, 2 green, 2 blue, 1 white). The circuitry seems simple enough so I figured I could throw this out at you gurus to pinpoint what might be the defective part, probably source it locally and swap it out. Any help would be greatly appreciated. Here are the pix.
