One option is to read the battery voltage. I would assume that the battery voltage is higher when the engine is running.
Another option is to pick up the signal from a tachometer.
Also, it's good to hear you've got a programmed chip and a cool mosfet.
Remember that any incoming signal will need to pass through a circuit to protect the chip from voltage spikes.
The AC signal you're talking about might have a relatively high peak voltage, but low average voltage (I don't know)
I'll draw you a quick circuit so you can test that.
