Hello all, my first posting so be gentle!
I am very much at the amateur end of the electronics spectrum. My dabblings have mainly been in passive guitar electrics, classic cars (pre 1985, before ECU's took over) and simple electronic repairs i.e. re-soldering failed joints in old audio amps etc.
Anyhow, this is what I am currently working on:
Farberware FP3000FBS food processor.
Approximately 1 year old (out of warranty).
It was working fine, then one day my other half went to use it and it was completely dead.
No lights come on, no noises, no burning smells, no smoke, just totally dead and unresponsive.
It should operate by pushing one of the four front panel buttons to select speed/ mixture function. These now do nothing.
I've taken it apart, nothing looks amiss and none of the components show signs of overheating or failing.
There's a main circuit board/ controller, and a satellite board with four micro-switches on it to operate the 4 functions.
There's a soldered fuse on the circuit board that is intact (it shows continuity when I put my multimeter across the pins).
The motor works fine when power (125v) is applied to it.
The safety pin switch is functioning as it should (only allows the processor to work when the bowls are latched into place).
Pictures below of the circuit boards.
Here's the main controller board (front and back):
And here's the satellite front panel switch board (front and back):
I've done some rudimentary testing using my multimeter.
With power applied, and the "negative" terminal of the multimeter attached to the neutral wire of the AC input, I am getting readings of 125v where the black wire is connected to the circuit board, and also where the brown wire is connected. The black wire on the circuit board appears to be the main power for the board, and the brown wire is the power for the motor. The brown wire is connected to one pin of the black relay, and it appears that the relay should activate to allow the circuit to complete to the white wire on the board (see the heavy silver tracks on the underside of the main board. This white wire goes to the safety switch (which is working correctly) and then to the neutral power cord wire. If I jump the brown wire directly to the neutral wire, the motor operates. Therefore, what I can deduce so far is that the relay is not switching, or whatever part of the circuit is controlling the relay is not doing its job.
I've also tested voltages around the board, and they vary from 125v to 60v near to the main black wire input, then seem to be around 0.4v around the main IC and the rest of the circuit board.
I've also tested the satellite switch board, and when the correct pin on the IC is monitored for a switch press, the voltage increases from 0.4 to 0.5v (all four switches are operational).
This is as far as my abilities can take me. With my basic understanding of circuits, I suspect one or more components is/ are not allowing the circuit to be completed, hence the unit appearing to be dead. But which component is it likely to be?
I am wondering if either the main IC has failed, or one of the capacitors, or a diode/ transistor.
These are the big items on the board that look to have the most affect:
I think I have covered most of the basics and supplied as much information as I muster! If I have missed anything, or further information is needed, please ask and I'll do my best to supply it.
Can anyone help guide me as to the next steps I should take? Any more diagnostics I should be carrying out to identify the likely culprit? Most of the components appear to be available new, so if I can narrow it down to the most likely failed components I can start replacing them and hopefully get this food processor working again.
Many thanks in advance for any help and/ or guidance!
