Hi everyone! How are you all doing? I'm a newbie here. I just would like to ask your opinion regarding FAN5345 function testing. What I'm actually doing is implementing the application sheet of this chip on breadboard (See attached figure), I have the exact values of the components except Rset which I replaced with 15 ohm resistor instead of 12.4 ohm. I've also decreased the number of LEDs into 6 instead of 8. I think increasing Rset is just appropriate since I used just 6 LEDs instead of 8. Also, I've added a tact switch connected to EN pin for dimming and a 0.1 uF capacitor to eliminate switch bouncing. I thought everything was all set, However when I plugged in the 5V supply for the Vin line, the LEDs didin't light up at all. By the way since I was using a breadboard to test the application of this chip I had to get a SMD to through hole adapter for this chip so I can mount it on breadboard. Here is the application schematic of the chip.
Any ideas as to why my breadboard prototype failed? I hope to hear from you. Thanks.
