Not sure where this should be posted so I've posted it to general discussion.
I want to use a fan-splitter to replace a single fan with two new ones.
The fan I've removed is 12V and 0.21A.
Assuming the header can support a fan of 12V and 0.21A:
Can I replace that fan with two 12V fans totaling 0.21A and not risk burning out the header, or will the wattage be too high?
E.G.
One fan of 12V and 0.11A + one fan of 12V and 0.10A equaling a total of 0.21A...
...but does that mean it's double the wattage?
e.g.
12V + 12V = 24V
24V x 0.21 = 5.04 Watts
Compered to the original single 12V, 0.21A fan:
12V x 0.21A = 2.5 Watts
I'm not sure if that's correct but it appears that putting two fans on the single header might double the number of Watts passing through the header even though their combined current matches that of the single 12V 0.21A fan.
Am I completely off bat with this? Is the above a correct assumption and can I assume it could be overloading and potentially damaging the fan header?
Thanks.
E.G.
e.g.
12V + 12V = 24V
Thanks.
