N Cook
A commercial mixer amp in a tiny box. By gut-feeling I don't like the
relative absence of air cooling and would like some justification to
increase the , at least output vent size - there is space for much larger
holes, but not necessarily aesthetic.
2 switch mode power supplies plus 2 100W rms D class amps and an 8 channel
mixer in a box only 10x6x2.5 inches. The 2 SMPS are "cooled " by a 12V 40mm
fan blowing the internal air, not positioned near any inlets, over the
heatsinks.
Inlet vents , if all 1/4 inch sockets should have tight fitting plugs in all
of them, are 30 x 2mm diameter holes.
The other fan is 12V, 50mm fan that pulls air over the 2 amps and exhausts
directly to the outside but via 8 small slots .44 inch long and .08 inch
wide that seriously restricts the flow out. The owner reports the exhaust as
being hot rather than warm and i've taken some measurements with thermometer
etc with relatively low continuous sine to external dummy load. I intend
giving the owner a thermometer to take some readings in normal use over an
hour of guitar performance.
I fixed, with sealing tape, a large diameter tube around the exhaust area to
direct into a very thin plastic rubbish sack, with no perforations, to time
and measure the air flow until about 2/3 full and holding the floppy bag up
as well so I'm assuming relatively little back pressure or whatever the term
is.
I did not think, while inside , to note any amp rating as well as 12V, nor
make and model, but generally 50 mm fans would be about 8 to 18 cfm cubic
feet per minute.
But from my calculation over 3 minutes then the flow rate was only 0.78 cfm.
This amp is designed so it can be transported and used , recessed into one
of the speakers, so not much heat lost through the walls of the box I would
have thought, I'm advising, interim, for the owner to use the amp removed
from the speaker.
Any comments on the adequacy of venting?
heatsinks.
is.
feet per minute.
from the speaker.
